SOLD Early cable shift 727
swampdonkey
4:55 PM
litchfield,me
Got two early 1964 automatics to sell cheap
I'm tired of bumping into them in my garage. Got cables, three different stall converters, performance torque plate, and a nice console if needed.
$250.00 for all parts except console.
Console is $400.00
20201215_184609.jpg 20201215_184203.jpg 20201215_165044.jpg 20201011_153101.jpg 20201013_150732.jpg 20201010_095437.jpg 20201010_095430.jpg
FWIW the two I can see the back end of appear to be 65 not 64.... One definitely has a slider yoke, the other looks like it takes a slider yoke... 64 takes a bolt on flange...
YES! both SLIDER yokes here's the casting dates i believe on the housings.
65 is more desirable than 64 since it allows you to use a normal driveshaft but still uses cable shift allowing folks to update earlier cars without getting rid of their typewriter....
I was under the impression you could get either one flange or yoke style in 65 I would think the yoke style would be the ones like mine
What input shaft do the converters use ?
Early or late ? I think the early shaft is 19 spline and the late is 24
Wish I was at that step for parts on my 64. Console looks nice.
PM = Personal Message
Both transmissions are 1965 big block 727’s and use the slip yoke.
Trans Part# 2466147 is a 1965 (late) 727 big block transmission and uses the slip yoke.
Trans Part # 2466112 is the early part number.
Both Originally found in B or C bodies with 361-383-413 engines.
Definitely one of the most desireable pushbutton / cable operated transmissions.
