can we all agree for my sake, that e street heads will outflow the iron 906s
The E-Street heads will out flow the stock 906 heads.
Heads flows from bench to bench mean very little even if the bench is calibrated each time. The orifice plate used during the testing makes a huge difference. More accurate for comparing heads is to run them on the same bench. Here are airflow and horsepower comparisons run on the same
flow bench and
dyno.
Lift.......Stock iron heads intake.........ported iron heads intake
.100.................61 cfm............................85
.200.................133...............................160
.300.................190...............................210
.400.................215...............................237
.500.................229...............................250
Now back-to-back dyno runs with a 7.8:1 compression 440 using a .500" lift cam and changing only from the stock heads to the ported heads.
RPM............Stock iron TQ/HP..........Ported iron TQ/HP
3000..................431/246.................434/248
3200..................442/269.................457/278
3400..................449/290.................462/299
3600..................436/299.................447/307
3800..................430/311.................443/321
4000..................438/333.................450/343
4200..................444/355.................461/368
4400..................434/363.................461/386
4600..................429/376.................473/414
4800..................419/383.................467/427
5000..................405/386.................459/437
5200..................383.379.................453/448
5400..................361/372.................428/440
And so much for cylinder heads not making a difference! There is only a 69HP gain at 5,200 RPM.
So what do the Edelbrock heads flow on the same flowbench using the same orifice plate.
Lift............cfm
.100.........73
.200........148
.300........209
.400........254
.500........276
Yep, I think the Edelbrock heads will work good on your engine.
Oh, yes, I've tested the Trick Flow heads on the same bench and with the same orifice plate. They're pretty damn good. Much better than the Edelbrock.
"We guess....."
"I've been told........."
"I read somewhere........."
"My buddy told me he heard......"
all
BS
I've personally tested them.
