spoolinhard
I'm not a member of the truck board, but think this is still relevant here. I Have a 74 ramcharger I'm attempting to put back on the road. Truck starts then dies immediately after letting off the ignition. If you hold the ignition in the start position, with the starter engaged, it runs. At the ballast resistor, 3 of the 4 terminals have 11.xx volts to them in the run position. The forth terminal that is connected to the secondary ignition (direct from the column ignition switch) has 3.xx volts with the ignition in the run position. If I run a jumper wire completing the circuit of the secondary ignition wire, at the resistor (top to bottom), the truck runs. I have tried 3 different used resistors (none have visible damage or signs of excessive heat), still doesn't run without the jumper.
I have checked the connections at the firewall and at the ignition switch connector at the base of the column, those are good. I'm thinking a bad column/ ignition switch. Thoughts?
Shouldnt the direct line from the secondary ignition at the ballast resistor, also have 11.xx volts in the run position?
