Northeast300
Best electronic ignition for my '79 300....thoughts, pros & cons?
it was removed before I bought it, long ago. It has an Edlebrock carb on it nowYou removing the lean burn ?
I am looking for performance, but would like to keep the factory look the best I can.If you want a factory look get the conversion kit from Mancini.I also recommend the up grade to their billet distributor for long term durability.Remember the lean burn TQ has no provision for hooking up the vacuum advance hose.Just a thought..
Small block, 360Is this a big block, or small block?
Small block, 360
http://paceperformance.com/i-238406...y-to-run-electronic-distributor-blue-cap.html
or
http://paceperformance.com/i-238406...dy-to-run-electronic-distributor-red-cap.html
both are ready to run type units that replace the OEM ballast, and ECM. these are a thousand percent the way to go vs messing with anything else in my opinion. Assuming this is a cruiser, opposed to a race car.
If you would ever consider a fitech or sniper in the future, get the billet unit, as it can be converted to work with those EFI kits while utilizing their timing control.
