mferraro76
Had the shop put the engine in before dropping it off at my house, it looks crooked? any way i can check this?
68 satellite with 318, 727.
The engines are slightly off set to the passenger side...is that what you mean?
Most Mopar engines are offset an inch or two to the passenger side for the reasons Brian mentioned.Well the engines in these mopars were offset slightly to the passenger side. They did this to cut down on vibration and allow a proper angle for ujoint lubrication as I understand it. Is the trans hooked up too? If not I could see how it could appear as the offset to the passenger side would further be exaggerated if the trans wasn't hooked up.
Check the transmission mount, there's some side to side adjustment.
gonna check that next. i tried measuring from the block to the frame, but i think the frame horns must angle in since the measurement drops about 1/2-1 inch from the front of the block to the back, on both sides.
If the shop bolted the engine to the tranny and you paid to have them do it I'd bring it back to them and have them correct it.
Unbolt the tc, loosen trans bolts, slide trans back enough tc/fp are not rubbing. Spin the tc and get it to engage the pump. To check the fp, spin engine by hand and see if its tracking straight.
The tc sits in from the bellhousing, offhand I think its around 1/4 inch. If its flush with the bellhousing, its not together right.
I agree. I'm definitely bringing it up with them. But i am to the point where i don't want them doing anything mechanical based on the mistakes thus far. they already screwed up the tranny mounts, they must of had a floor jack under the tranny pan based on the scratches and dents they left. i guess as a body shop, the mechanical stuff is not familiar to them.
So if the converter dogs are not engaged properly, the converter wont spin freely?
