Curious how many of you racers engine brake after the stripe or go to neutral? Pros and cons of each?
so you have a low band apply valve body?I just lift at the line and let the motor slow me down. I have a reverse valve body so I cant go to neutral without hitting low gear first (no good).
If you say so.:shruggy:
I was just going by what Rick Allison(A&A Transmission) told me when I bought one of his trans. He told me not to try and put it into "N" after my run because it would go into 1st before it would go into "N". I guess it has something to do with to much trans pressure for low gear.
I guess I could have gotten the manual valve body with the extra "N" and the cheetah shifter with the same feature so I could go into "N" after my run.
I just looked at A&A Transmissions website. I have the Comp + trans and it states it has a low band apply. It is a street/strip trans so I figure that is why it is set up that way.
A car that runs 11's 1/4 mile needs to go to neutral. The firing order of an engine is done to keep the twisting even along the crankshaft. At the end of the run those slicks and low gearing can and will over time break the crankshaft at the flywheel end of it. Been 40 years sense school but best I remember a 3400# car/4:88 gears/11X29 slick that runs 12"s put like 50 tons of reverse rotation on the crankshaft in one spot if you just lift at the end with a 1to1 high gear.
