chrisd
I finished pulling the engine and trans from my donor '86 Fifth Avenue and the trans has a weight(?) attached to the end. It doesn't attach to anything in the car. It's been a real long time since I've worked a V8 Chrysler from the '80's, so what is this? Is it neccesary? Is it some kind of balance weight or what?Also, the oil filter has an adapter that faces the oil filter to the rear. Is anyone aware if this will clear the frame or do I need to pull it and put the original in place? It's going into a '67 Charger.
