Y07Roadrunner
- 1:10 PM
- Jul 20, 2016
- Maryland Eastern Shore
Today after idling for a little bit I turned off my ignition switch and the engine kept running. I could only get it stopped by pulling the coil wire off. With the key out of the ignition entirely, the amp meter still read in the negative and the parking brake light stayed illuminated - this usually only comes on with the key in the "run" position. The engine starts and runs fine, but the amp gauge reads negative when the engine is running. All wiring connections look good and no other electrical-related issues are observed. Thoughts on this??
