Seriously on a Mopar using the RV2 compressor before jumping to any conclusions let's talk about the STV or EPR valve & where you are reading the pressures at...
There's more than one port on the low side of Mopars.. One is reading the evaporator pressure & one is reading the true low side after the STV/EPR valve.... The evaporator pressure isn't gonna read as low as the true low side...
STV is the Suction Throttling Valve
EPR is Evaporator Pressure Regulator
They both do the same thing, just in a slightly different way... Engineers like to try different stuff... They maintain the evaporator pressure when the system is undercharged to prevent the evaporator freezing...
The true low side port is on the passenger side head of the compressor, the Evaporator Pressure Port is on the manifold bolted to the back of the compressor...
THE STV/EPR is located in the suction port of the compressor, it's just slid into the port and captured by the manifold... Remove the two allen bolts & pull the manifold... When the EPR/STV fails it'll read like a bad Expansion valve
I doubt you can find a new STV/EPR valve but you can simply take it out & the system will work like a typical A/C system...
