am3rican
I feel like I've researched this one to death but can't find answers to several questions.
I have a 68 Roadrunner that was converted to electronic ignition (with Orange box). When I received the car, the tach did not operate at all. It is pegged at '0'. I am guessing it is due to the electronic ignition. I would like to get the factory tach working again. I have not done any diagnosis other than checking voltage to the fuses in the fuse box. I am not sure where to start given my setup. All advice I have seen is based on a points ignition setup.
I have read that there is a device or switch I can purchase that will get the tach working again. Can someone tell me what it's called and where to source it? To those who have gone this route: is the tach accurate and does it bounce?
I have called Redline gauge works. They want $200 to convert it. Plus cost to ship the gauge there. Not sure If I want to spend that much until I explore all other options.
Also - All other gauges are in good working order. Only other complaint is that the dash light does not come on. Again, I have not diagnosed but I am convinced the previous owner tried to solve the issue as the dimmer wheel looks new, and I have a box of parts with dimmer switch / wheel with corroded connectors.
