fender tag decoder
MoparPat1
7:22 PM
Oxnard, CA
Hello everyone, I'm looking at getting a 1973 road runner, the vin is RM21G3G202234, It's showing it's a belvedere or satellite, or a medium road runner, also where can I find a decoder for the fender tag, thanks
Great, but it looks like it has an 8 1/4 rear end, is that possible, it has disc in front, trying to decode the fender tag. I might be able to pick it up for 2,500 bucks
Any car ****? Looking like a base model 318 RR. I have a 74 that was a loaded 318 car. There are Mopar vin decoders all over the web. Keep us informed, I like seeing other RR's and sharing tips! Take care, Scotty.
yep don't look that special I guess, what does "delete transverse r/t stripe" and also it says tx9 paint code black/black velvet and tx9 upper door frame black/black velvet, it did have chrome exh tips and dual exhaust, and also has a tach, but I did notice it did not have the 150 mph dash, oh well, body pretty good and it comes with a brand new 318, which I will sell and make it a 440 car, if I get it. One bad thing, someone put a moon roof on it...:-(
Amen brotha! Its only a 318, you are not ruining a "one-of-none" car! Make it what you want, just like I am doing. BTW, I just did a roof replacement if you need help. Mine was rolled!
it looks like they did a pretty good job installing the moon/sun roof, no leaks and headliner has no stains, just might leave it, thanks for all the help and I will be bck with pics and more info
are you sure that is not a factory installed sun roof? i had a 74 sat w/sunroof from the factory.also sounds like it was a stipe delete car.but it sounds like what you.ve got is a very good deal for whatever you want to do with it. good luck.
how would you tell, it does look like it was installed from the factory, would I need to find more fender tags or build sheet??
Pm me the tag codes and I can decode it for you.Is it a glass sunroof or does it crank back and its open (no glass). If it is a crank back and is factory it will have drain tubes in the rear wheel housing for the crank back roof.
Jim
Jim
it's clear glass, I think it's electric, or does not move, will have to check
I think it would say M52 or M54 on the fender tag can remember which, but that was the code for the moon roof.
AL
Here's some pics of this car
100_3066.jpg[/ATTACH]
sorry pics are so big. it looks like it has an 8 1/4 rear end, and check out that (if you want to call it that ) wing, I should have took more pics of the sun roof...stupid....
neither am I, will get the original one for it. trying to figure out where in the hell did he get that monster. I'm surprised it has the smaller rear end though, being a roadrunner, but it is a 1973, so,
