Filler Neck Grommet 1962 B Body??
threewood
1:42 AM
Artesia, NM
I have no idea why I cannot find this grommet! They start at 1963 and go up. What is the difference? Filler tube is 2", hole in replacement tank is 2 1/2". Who carries the correct one? Mine is split and leaking like a sieve.
Not sure if there is a difference in the 62 or later other than looks. My 63 had just a "O" ring but was replaced with a later style that worked fine.I ordered one for a 88 Dodge truck and it was the same as my 79 Chrysler and 65 Belvedere.
Ok, thanks. I ordered 2 hopefully one will work. One looks like what Kramer has listed. The other is rounder and said to fit 63 thru 74. I guess anything is better than a ripped one.
Yeah, for lack of a better discription some may be taller or thicker if you would but work the same. I do know that the early "A's" were smaller in diameter.
Thanks for the help. The one I ordered for 63 to 76 B Body worked perfect. Tight on the tank and tight on the filler.
For reference, ordered from Filler Neck Supply. #GR004-02 1963 to 1976 B body
