Filling new power steering system
Beekeeper
It’s a disease without a cure!
3:11 AM
Rogersville,TN.
Installed new gearbox and pump and new lines on my 69’ bee. Can I vacuum fill the system before start up? As in pull vacuum on the return port on the box and through the pressure line and pump keeping the fluid level in the reservoir above the pump. Planned to use a length of hose connected to the pump return port and the open end higher than the fill spout on the pump. I know the old way of bleeding the system just thought about vacuum filling it if possible.
I did the lock to lock bleed with a new gear box and new pump. I went through about four bottles of fluid before the bubbles all disappeared drained into an oil pan during the turns. I needed a helper to turn the wheel while I watched the bubbles and refilled. Sealed everything up and once the car started no bubbles and no fluid needed. YMMV.
