ronw
need some ideas on how to run my wiring from my gauges through the firewall that is safe from being cut and water proof.Thanks Ron
You could drill a hole or use a hole saw. Install a rubber grommet, run your wires, then seal it with a/c sealant tape. The stuff they put around a/c lines where they pass through firewalls. Not sure what the exact term for it is but auto parts stores should have it or be able to get it.
