Geri
Deceased, But not forgotton
I'd like to eliminate all -or as much as possible the wiring from the firewall, but having total brain fade on where /how to re route the wiring- idea's please.
thank you a picture is appreciated.I don't have any pics at work with me but I completely did away with the bulkhead connector and fabricated a panel with a grommet to fit that hole. I ran everything that needed to go through there to that side through that 1 little (somewhat little) hole and loom to where it needed to be. Because I completely ripped out my old fuse panel and mounted new one under the dash, I was able to keep pretty neat and run another hole out the passenger side for ground and that side of the motor.. I will add a pic or 2 when I get home tonight if it will help.
hanks -that is kinda what I have in mind. the individual wires to the engine starter relay etc. are ugly.Depending on how or what the planned use of the car is, we did a 64 Barracuda and ran everything in the fender well (under)along the top. We built a box/shield to keep dirt /water and the like out. We even ran the A/C lines on the other side passenger fender the same way.
this is my street car- with heater only- no other electrical inside. so ign, alt wiring lights and horn only under hood wiring.Depending on how or what the planned use of the car is, we did a 64 Barracuda and ran everything in the fender well (under)along the top. We built a box/shield to keep dirt /water and the like out. We even ran the A/C lines on the other side passenger fender the same way.
right now it's 383, goingWhat engine are you using ?
I like the odd manifold by edlebrock, mainly because I have it.getting trans throttle pressure kick down is an issue.Nice !
If you want to hide it all including the fire wall wiring it can through the floor. Then into the frame rail forward. Look below the firewall above the right frame rail, that's where it enters. Then the wiring exits just behind the passenger motor plate tab. At this point all the body wiring is in place.
Doug
that looks great and a great idea. thanks.
