gto64gto
I have a 65 Satellite with 440. I had no heating problems. 180-190 degrees, 200 at most.I have a Mopar flex fan. I installed a milder cam, and a dual plane intake. I noticed the water pump was sweeping so I replaced it with 1 from Advance(same style air condition pump). I have a mechanical Auto Meter gauge. When I fired it up with stock radiator, temp went up to 240. I replaced thermostat with Mr Gasket large 180 stat. Temp came down some but not enough. I hade an aluminum 2 row 1 inch flu radiator I put in. Not a lot of difference. (My timing is 15 BTDC and no vacuum leaks-checked with propane). Has anyone used a Flow Cooler or Edelbrock water pump on a warm 440 that seemed to help the cooling? Any help would be appreciated. Thanks.
