FOR SALE Fram PCV valves 1961-69 NOS
Michael Kocan
10:31 PM
United States
Feedback: 1 / 0 / 0
Hello all, Found some more of these Fram PCV valve kits. Early manufacture as the package only shows application up to 1967, however they are used untill 1969. # 132 package shows all 6 cylinder and package #131 shows all 6 & 8 cylinder. They are exactly the same in style, length,contour and grommet diameter. New rubber grommet embossed with the Chrysler Pentastar # 2536926, black phosphate coated and the nut. Asking $25.00 each + $5.00 shipping using USPS Ground Advantage (3-5 day) arrival time. So, here is what you have, a total of $30.00 for the part shipped to your door. Payment can be Paypal,Postal money order or personel check. Located in Millville P.A. 17846. Thanks for the ad FBBO. Oh, this helps support my Charger rebuild and I thank you. Kocan
Hello all, Found some more of these Fram PCV valve kits. Early manufacture as the package only shows application up to 1967, however they are used untill 1969. # 132 package shows all 6 cylinder and package #131 shower all 6 & 8 cylinder. They are exactly the same in style, length,contour and grommet diameter. New rubber grommet embossed with the Chrysler Pentastar # 2536926, black phosphate coated and the nut. Asking $25.00 each + $5.00 shipping using USPS Ground Advantage (3-5 day) arrival time. So, here is what you have, a total of $30.00 for the part shipped to your door. Payment can be Paypal,Postal money order or personel check. Located in Millville P.A. 17846. Thanks for the ad FBBO. Oh, this helps support my Charger rebuild and I thank you. Kocan
Hi would you have a Fram PCV valve kit 132 ? Thanks
