mferraro76
What am i doing wrong? I had the whole thing together and the pulleys won't line up. The water pump pulley is about 1/4 inch too far in and doesn't line up with the inner crank pulley.
My specs: small block, 318. I am 100% sure the harmonic balancer is snug up against the crank gear. I thought i might have the wrong crank gear but it seems to match what advance auto had in stock for the 318.
I thought i might have the wrong water pump, but it appears to be the right one.
I bought a new timing cover, but it measures the same as my old one.
Basically i have torn the whole front of the engine apart trying to figure this out. Can someone either help me with this or give me some measurements to check - like the thickness of the lower timing gear, length of the water pump, length of the harmonic balancer, etc? i can't imagine that i should have to shim the WP pulley a 1/4" out?
