dieseldazzle
For whatever reason when I jack my 67 charger up in the air and spin the passenger side tire it has severe drag on it. I tried to loosen the brake adjuster (power drums) thinking it was too tight but that didnt do anything.
So i removed the tire and the drum falls right off.
I thought the front drums were press fit to the front hub and had to be removed from the hub with a puller and/or some heat.
Everything looks fine.
When I put the front drum back on and adjust the breaks where they need to be, making sure the hub bearing is adjusted correctly, the tire spins free with light drag from the front brakes.
Problem comes when I torque the tire on.
Again, the passenger side tire is almost impossible to spin by hand.
only when I remove the tire does it pop free.
I thought maybe the backin plate was rubbin the drum but that is not the case.
So i want to just buy another front passenger drum and hub assembly but every parts house I go to order from shows the drum without the hub.
is this just a generic pic and you actually get the drum, pressed on the hub or not?
Ive only worked on 10 or so front drum brake cars and I can tell you that everyone of them had the hub come off with the drum.....
Thanks.
Thanks.
