96Formula6sp
Hey guys asking for some help with some very uneven brake wear on our lemons car. The last two sets of pads have had some uneven wear side to side. Our current brake setup is a set of 79 Dodge Magnum Brakes on 73+ Dart spindles. Anyways our first race we sway some uneven wear. First race the Drivers side front brake had about 1/8th of pad when we swapped. The passenger side was about 1/3 of pad material left. This was after about 2 hours of testing and 10.5 hours of race time. We checked them at 2 hours and wear was even side to side with maybe 1-2mm of pad gone. Using G-loc r16 pads.
Our second set of pads went on at the CMP event however we had some clutch issues with the Ar-5. Anyways they ran some CMP and Barber. At the end of Barber the drivers side pad was gone. There was probably nothing left when I went out with 1 hour 45 mins to go. Fast forward to last weekend were we were putting some new pads and rotors on the car for an up coming test day for the new engine. These were the pads I took out of the car. Probably have close to 16 race hours on this set. They were due for a change but we forgot while fixing other bits of the car.
Drivers side left passenger right.
Outer pad. Hard to see. Passenger side on left drivers on right. Backing plates are on the outside. And yes I know the shim is on the wrong side of the hold down bracket.
Inner Pads. Passenger on left drivers on right.
So we are curious what could be causing this. Are these cars biased towards the drivers front. We took the brackets off as they came from an Ohio car. The inner pad was sticking some on both side. A light file got the area flat again and they pads are free to move. Was thinking it could have been a sticking issue but the passenger side was the worst on the light sticking of the pad. We are not using the anti rattle o-rings. Debating if the brake proportioning valve is stuck. Calipers have two races on them as well as the soft lines.
I will say that I ran the car at the Barber race and was first out. Cars braking was pretty straight. It will wonder some but no issue on fresh pads. I was the last one out and the car was pulling left very hard under braking. Granted I was using the brakes as little as possible but still when on them it would tug to the left due to the uneven pad wear.
Any ideas or things to look into.
