In the process of getting my 69 Super Bee back together and decided to upgrade the front brakes. Engine is currently out so trying to get everything sorted while I have the added room to work. I think I have it figured out but wanting to have my plan looked over.
Old setup - 4 wheel 11" drum, manual 1" oem master cylinder, OEM distribution block, roll control
New setup - 10" front discs w/ sliding calipers (retain rear drum setup), manual 1" Wilwood Compact MC (4 bolt), Wilwood proportioning valve, same roll control
The Wilwood proportioning valve I have mounts to the master with a bracket and has front/rear inlet and front L/R and rear outlets which from what I can tell should replace the stock distribution block. My plan is to make 2 new lines for the front brakes and a small jumper for the rear with a union - does this sound OK?
From what I have read the residual pressure valve was built into the OEM master cylinder, so I have a 10lb valve from Wilwood I was planning to plumb into the rear line - is my thinking correct? And does it matter where in the line I plump the valve in? Closer to the master cylinder is what I have read.
My other thought was to run a single line proportioning valve on the rear line and retaining the stock distribution block - any reasons this would be better? I would still need the residual pressure valve but would not need to make as many new lines (car already has roll control so that complicates things a bit too)
