Front disc for '64 Polara
Hambony58
3:55 PM
San Jose Ca, US
Looking for brake kit w/out master cylinder, I have a big aftermarket unit for the car. I am not that interested in scouring boneyards for the '76 components, that leaves aftermarket stuff.
Not interested in race brakes( Wilwood/brembo etc...) don't want to break the bank, so.....my main concern is that I am seeing some charts that start at '65 and want to make sure that the 1st order is the correct peices.
Will I have to swap out the upper control arms?. Please don't recommend Classic brackes out of Colorado as I had a mediocre experiance with them already. Thanks in advance. Hambony.
I would stay away from Ram Man. I had a terrible experience with his product and his customer support.
Wilwood has a vented rotor (like oem) Pro Street kit that will bolt to factory drum spindles.
Yes, it's a little more expensive but used with a readily available $26 aluminum master cylinder from Autozone, I have under $700 in my conversion and saved a TON of weight. Rotors, bearings, calipers, brackets and master cylinder. Fabbed up some lines and a new dist. block.
Really happly with the way they work!
I went with the SSBC 4 pot system. Small enough rotor to clear the factory 14's, but plenty of stopping power. Good value too.
Thanks mosquito13, I went with the factory reman stuff from Wayne the ram man. I appreciate it. Hambony.
