LJR 70
Read all the threads I could find on Fuel gauges
Working on 70 GTX fuel gauge that used to work, temp gauge toasted, oil seems to be working Grounds have been checked and rechecked at dash and tank
1) Have 5.06 volts at tank
2) When I ground 5vt wire the needle goes to full
3) Pulled fuel tank, pulled float, float reads 14 ohms on full and 75 at empty
4) Connected the float into wiring harness at vent panel and moved the float. At empty the needle sits all the way at the bottom. Moving the float up to full it only reaches the halfway point on gauge and stops
5) Seems to be questions about Rally gauge vs Cluster, is there more of a difference than just looks ?
6) Thing gauge is bad but...
7) Think adding a resistor would make it worse
8) added pics because we all like them, hope this works
