Fuel Line Routing
bandit
7:36 PM
Illinois
Had a few sections of the fuel line patched with rubber line(especially by the tank) so bought a full length pre-bent line. I have the rear tire off and have the line routed from the front ok but am not seeing how this goes in around the exhaust in the back. And the angle of the end of the line looks like it lines up to the tank fitting at a right angle? I know you have to use rubber hose here to connect the two but it would make more send if it came in straight on to the tank fitting. Anyone have a diagram of the fuel line routing back there? My book does not show it.
Knowing kind of car might make a difference.
Made my own lines for 64 Ply. Fuel line has to snake around wheel well area, around the frame, up to the under body, and down from there to the sending unit. Also has a metal clamp around the line, above the sending unit at the under body, that serves as a positive ground...steel line to body.
......and POOF! The Op disappears as if he owed me money.
