old guys rule
Has anyone out there tried using driver side all fittings on a Holley carb 4 fuel recirculation to the tank?
Was wondering if it would keep cooler fuel in the Bulls and send Vapors back to the tank. Probably not bothThat might work if the regulator was down stream of the carb (like TB fuel injection hook ups). It would provide a little fresher/cooler fuel at the needle and seat. This would require the center hung float bowl with 2 inlet tappings per bowl.
Mike
You might be able to do that with a very small restrictor in the line. Otherwise all your fuel pressure will be gone and most likely be starving of fuel.Has anyone out there tried using driver side all fittings on a Holley carb 4 fuel recirculation to the tank?
Thanks for the help guys. Always thinking of ways to get myself in trouble.You might be able to do that with a very small restrictor in the line. Otherwise all your fuel pressure will be gone and most likely be starving of fuel.
