fuel sending unit volt pulse?
TRAMO
5:05 AM
LEBANON TN
should the fuel send unit wire be pulsating. with a meter the voltage pulsates.
only if the gas is sloshing around,changing the reading.if it is steady,then the unit has one or more bad spots in it.
Yes, what you are seeing is the "regulated" +5V DC from the voltage regulator in the instrument cluster. It takes the battery +12V DC and "pulses" it to where it appears to the instruments as about +5V. Its not a real good regulator (points type) but that is how they did it back before solid state electronics became the norm.
I am assuming that you are checking the wire in the rear of the car when it is removed from the sending unit stud, one probe to the wire and one probe to ground?
When connected to the sending unit, the sending unit provides a variable resistance TO GROUND. MORE resistance, less fuel indicated on gauge, LESS resistance, more fuel indicated on gauge.
