full length headers?
jrod0877
6:25 AM
Colorado Springs
Hi all, I have a 1970 barracuda 340 SB. im putting it in a 1973 roadrunner. my question is should i get full length headers for it? Im not sure if they will fit on my car... i would appreciate any help... Thanks Jrod
An LA small block...is an LA small block. Doesn't matter if it's a 318, 340 or 360. They will fit.
Just don't buy the cheapest &/or thinnest ones available... spend a little extra $$$, get some quality headers & they will fit & last a long time... usually B-Body with small block cars, have a ton of room... as long as the car isn't too low it shouldn't be an issue...
IMO, there are only 2 header companies out there that make a header worth installing. That would be Doug's or TTI's. Pricey but OH SO worth it.
The only exception to this rule would be Hooker Super Comp headers. A slight bit cheaper than the above (but do Re-check!)
The Super Comp headers are a 1-3/4 pipe X a 3 inch collector. Use them high horse applications.
*All other headers* will have 3 tubes running under the front end linkage and will get flattened by the road, road debrise, speed bumps, etc....
A waste of money to purchase them IMO.
* of course there are the shorty headers, LMAO!!!!
I agree with "rumblefish360" as TTI and Doug make the best headers out there. Ron
