cherokeechief79
while trying to find out the problem with my gas gage i recently filled it up to check the needle.
it all points to the sender and with all of your help ive located a sender for my wagon which seems to be the same as any b body.
how much gas do i need to get out before removing the sender.
ill have it up high in the rear on jackstands which will probably make it even worse.
