GENIII Swap Question
dart4forte
4:46 PM
Mesa, AZ
Anyone here running a GENIII swap with a 727? If so, just curious as to how you addressed the Kickdown?
I have no experience with these swaps but I think you need a cable set up corrected to the leverage angle of the throttle body-to duplicate stock rod movement or go right to a manual valve body and eliminate all connecting linkage. I am sure someone else will chime in!
Mike
It is done by a cable, from the drive by wire box.
My brother is doing a swap in my nephews duster using a throttle body on the gen 3 hemi and using a Lokar cable. RUFFCUT
Sorry no picture!
I used the crate motor intake with a 4150 throttle body. Started with factory big block kick-down and modified the lengths.
