jkr3811
New Member
anyone have the support bracket I need (I believe it's the passenger side) for this upgrade ? I'm going from the stock 22" radiator to a 26" wide one. My car is a 1968 charger with a 440. Thank you
Thanks. I am going all out and going to buy a new passenger side mounting bracket but, thanks for the advice. Fingers crossed on this 440source water pump. We'll see. I've heard thingsDid it many times...I just put the 26 on the drivers side mounts...leveled it...and drilled new holes on passenger side. Shroud lined up perfect and almost 100% of the core was exposed to air I did use each direct fit from champion and the trans lines lined up well also. I suggest asking for a 26 inch with 2, 1 inch tubes for your car with a 440. I have the same rad in my 67 R/T with a 472 hemi...shroud and 7 blade steel fan...runs cool
