I prefer the OEM tapered rollers. I have disassembled a Green bearing and I was not overwhelmingly impressed. The one I had used a plastic crown style ball retainer and it was failing. The fact is the tapered roller bearing has more rolling elements to distribute load as compared to the Green bearing. My life revolves (pun intended) around high precision high speed ball bearings, including the angular contact ceramic variety, so I can provide some insight on the subject.
The separable angular contact bearings shown in Rusty's link are probably set up as a duplex pair with the preload built in to the bearing, similar to a machine tool spindle as found in a high speed CNC mill. The key to making this work is you actually have two rows of ball bearings per wheel to spread the load out over more rolling elements, and the use of the angular contacts eliminates the friction associated with tapered rollers. Angulars do have a thrust component in one direction but from what I know they still can't match a tapered roller in terms of thrust and radial load. I believe most modern 4x4 and FWD cars have this duplex angular contact bearing / hub assy., just not ceramic, and they seem to do well. The Green bearing is a single row and I don't recall it being a deep groove design.
I have Greens on my GTS because that's what was on it when I got it, and I didn't have another set of factory plates, so in the interest of expediency I just put Greens back on. Reason I had to replace the bearings is because one was noisy. But in all fairness, whoever removed the old bearings cut into the axle seal area out by the flange and water was able to get in and damage the bearing. My fix was to make a repair sleeve. I don't drive this car much so I can't offer any feedback, but as of now the wheels haven't fallen off.
