kaj750
1969 Charger.
Soo... I am finding search results for each of my problems.. but posting in case they are related, seeing how nothing on this car has made any sense to me LOL. Also, I realize none of this is going to make sense to anyone else, anyway... because nothing on this car does. Here goes, anyway....
My current problem:
My headlights have decided to stop working. All other lighting on the car is fine except:
Just before the headlights stopped working, the lights on the the right side of the gauge cluster stopped working. It's from the right half of the speedo all the way to the right. Radio lights up, so it's just the cluster.
random factoids:
*The cluster lights went out before the headlights.
*I've had the cluster out recently. Everything was plugged back in properly and confirmed working other than windshield wipers, which recently, magically started working and are still working. I installed new bulb receptacles in part of the cluster because the old ones had broken tabs/were loose. I believe these are the ones that decided to stop working as I remember working from the amp meter side as it gave me problems originally (the broken tab on the bulb holder).
*One of the times I turned used the headlight switch, the dome light came on, as if I were using the cluster brightness dial.
I'm going to document the process in case anyone else has my specific issue, as I assume it will be unique because this car was built... questionably, by the previous owner. Does any of these things catch anyone's attention right off the bat?
This week I'll start with the usual: testing for power at the light harness itself, double checking grounds, etc. I'm just hoping for a "hey! That happened to me. Try...."
I just can't understand how this part of the car worked perfectly and now it just doesn't. If something happened to change anything, then at least I'd have a clue of where to look.
My current problem:
random factoids:
