how can I test the dimmer switchSounds like it needs a dimmer switch
I tested both headlights/both goodor two new headlamps
Can’t get from under dash?I tested both headlights/both good
I tested dimmer switch/good
Must be light switch....seems like a big job for hi beams that I'll probably never use.
I just checked...I guess I could w/the removal of some A/C hardware/Can’t get from under dash?
If you have low beams the headlight switch is doing its job. Get a volt meter and test light and actually diagnose the problem. Its a problem at the dimmer switch or the wire from there to the headlamp bulb.I tested both headlights/both good
How did you test the dimmer switch?I tested both headlights/both good
ohms meterHow did you test the dimmer switch?
Need to test under load. With OHMs you might get a reading but it will go away under load.ohms meter
