Headliner Rear Listing Bow Support Wires for '74 SE
Gold Rush
1:34 AM
San Angelo TX
Finally getting to installing the headliner in my '74 SE Brougham. Somehow the two support wires that attach to the rear Headline Listing Bow have vanished! Does anyone have some they'd part with or maybe send me photos and measurements so I could make them.
Thank You in advance!!
You should be able to measure and make your own. The rear bow should stand straight up and down with the wires restricting the forward tension not allowing the bow to move past 90 degrees up if I am correct and the remainder of the bows and material will put tension on that rear bow and the retaining wires to keep it taught and from moving forward.
That was my "Plan B".... It's a good option if OEM or the duplicates are not sourced. Thanks for the response.
FOUND ONE!!!! Actually, our good friend NACHO did. :thumbsup: His ebay skills are soooo much better than mine!!
I hope won't be needing a set of those if missed while my car is at body job. Will know when reassembling. I hope soon
