I have removed the heat riser butterfly and shaft from the passenger side manifold and now am faced with filling the two holes. I have seen other posts on here about filling these with nuts and bolts but want to take a different approach.
I went and purchased a couple of different styles of threaded plugs and was hoping to get some input on which would be best.
Style 1 is a 1/8 NPT brass plug and style 2 is a 7/16 steel hex head plug.
By far the easiest to install will be the 1/8 NPT brass screw as the existing holes are already the correct size so I just need to run a tap in it. Using the 7/16 steel screw will probably require drilling the hole out slightly before threading it.
So I guess it comes down to whether the brass plug would be able to withstand the heat and if the expansion/contraction rates of using dissimilar metals would pose any potential problems.
Thanks ...
Thanks ...
