Heater Blower Motor
Michael Maresca
3:17 PM
Toms River
Good Afternoon. I am restoring my heater Box entirely. I know that there was a heater Core leak so I sent out for refurbishing. But I was wondering what the easiest way to tel if the blower motor works. Someone told me to hook up to a 12V battery. But there is a plug end on one side. What would someone suggest I do?
The wire with the screw is ground and the other wire gets the 12v... If you have a battery charger, the clips are easy, or just hook a jumper wire in the connector plug, disconnect the grounded wire screw and touch the ground wire to the "Neg" terminal and the connector-jumper wire to the "Pos" terminal.
