Heater controls
al383
8:16 PM
Barto PA.
Having problems with my heater I believe it's in the wires but I am not sure .on the medium speed when I checked it it has 12 V coming from it .The low and high does not have anything that shows on the meter,Could it be the controlsUp on the Dash At the start of the wiring or is it the plug .this is on a Dodge super B 69 As always thank you for all the help that I get on this site .
Might be the resistor on the a/c box..It controls the speed of the blower motor.
I to was thinking the same, do you know how to change that pc. thanks for help
I found out what the problem was With the blower motor on my heater. A few different things went through my mind . As I was putting the heater Box in I kept checking The blower motor , it worked the whole time until I had it Bolted up . The 3 bolts that Holds it up against the firewall where too tight is stopped the blower from rotating . I thought that it would be something else to check if somebody else had the same problem problem I learned something new every day .
