I've had five GTXs with the heavy duty cooling system, which included a 26 inch radiator. Two factory '69 A/C cars, one had a direct drive fan from the factory, the other had a thermal drive, which was the usual set up. Seven blades on each, with shroud. One '69 with Performance Axle Package, one '69 Track Pak 4 speed, and one '68 Hemi automatic- fan on each of those was a seven blade viscous drive. Three row cores from the factory. Current A/C car had the original radiator re-cored with a two row, with bigger tubes than original. No cooling issues, when running A/C at 90 degrees.
My unrestored '68 GTX with automatic and no A/C came with a 22 inch radiator, a shroud, and a seven blade direct drive fan. Never had a cooling issue after I had the original radiator re-cored.
