Hellcrate wiring can bus interface device issues
noblegtxman
3:55 PM
surprise, AZ
Hey guys,
I thought I was getting wrapped up on my hellcat swap, but I have an issue I'm not sure how to fix.
I installed the hellcrate complete wiring harness, pcm, pedal, etc. (Hind sight I would have put a holley terminator in it) I got everything wired up and the car starts and runs, albeit very poorly, but I cannot connect to the pcm with anything.
I took it to the dealer to hook up with the witech 2.0 tool to do the pedal learn, etc. But their tool wouldn't connect. I brought it home and tried to pull the tune out of the pcm to send it off to hptuners, but my computer and rtd won't connect to it either. I did get Vector CANoe to connect to it and show that there were messages being sent(which is weird). I checked the pin out for the obd2 connector and it all seems correct.
I noticed today that the can bus interface device doesn't have a green led light like it is supposed to when it is powered on. It flashes a red light 5 times and then goes off. I double checked all of the grounds and went though all of the wiring again, but I can't find anything. Has anyone else had this problem?
Hey guys,
Go to the Hellcat Swap Facebook page. They have several knowledgeable guys there.
Welcome. Do you have a build page here?
I should've done one, but i didn't. I stripped it down to the shell and redid everything. RMS front and rear suspension. Wilwood 13" brakes with an electric booster. American racing forged wheels with pilot sport tires. 18/19 combo. The list goes on forever.
