64SF
I have a 2002 Lincoln Blackwood that came from the factory with a power lifted tonneau cover. Lincoln only produced this model for one year. They thought they would sell a ton of them but only sold 3,300 units. The power module that sends signals to the lift motors was a poorly designed unit and failures were frequent and almost guaranteed. The power module replacement is no longer available (anywhere!). I have found an aftermarket module that powers lineal actuators which has been used to convert manual hard tonneau covers to power lifted covers.
Long introduction to a electrical question...
The Blackwood uses two 12 volt motors to lift the cover, they run in forward and reverse (up and down). The motors have, which I believe, is an electro magnet drive mechanism that engages/disengages when power is applied. When there is no power to the motor the magnet is in "neutral" which allows you to manually lift the cover.
Here is the question....the motors run both in forward and reverse but the magnet is not engaging to the motor flywheel...any thoughts on how the power would would be provided to the flywheel? Maybe through the pins to copper rings in the flywheel side similar to the exposed side of the magnet?
I'm hoping to use the aftermarket remote unit to power the motors. I've wired the aftermarket unit to the motors and they will run in forward and reverse but the magnet doesn't engage on either motor. If I don't figure out the motors I can install the lineal actuators but the problem with that is if there is a power failure or a actuator failure I won't be able to open the cover manually (?).
Below are pictures of the motor, the flywheel and magnet and the assembly the motor is attached. Please excuse the muddled txt on the photos.
![Tonneau cover motor 1.jpg Tonneau cover motor 1.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/237/237206-41cabedaa7dcc9b26e748f190897a589.jpg)
![Tonneau cover motor 2.jpg Tonneau cover motor 2.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/237/237207-911eceba272aa591f75c08de1478a65d.jpg)
![Tonneau cover motor.jpg Tonneau cover motor.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/237/237208-b1834b1e190c8151b459ec8898b254e9.jpg)
