2quick
I'm in the process of installing Brand new lower Hotchkis LCA Pivot Shafts into A brand new QA1 K Member but it seems like there is a lot of up and down Play/Slop between the two. Is this normal? I checked it against my factory K Member and the play is there also but I don't have factory Pivot Shafts to compare. I can't see the the torsion bar actively supporting the the other end of the LCA and would think that tyhe pivot shaft would fit much tighter....
