Lee Hulan
I'm trying to get the axels out of my 64 polara. I'm not familiar with the castle bolt and hub style. Does anyone have some input as to how I should go about taking these out. All help is appreciated.
Save yourself a lot of grief, and use only this type of puller. Be sure not to "mushroom" or bugger up the threads on the end of the axle. And be CAREFUL ! sometimes when that hub lets go, it will come flying off of there...............................MODo not under any circumstances hit that thing with a hammer. Use the correct puller or you will ruin the Hub. The hubs cannot be replaced. Nobody makes them. The only place you might be able to find one would be in a wrecking yard. You don't want to go there. Get the correct puller to pull those hubs off. Then you can pull the axles out.
Someone has converted his drums so they can be taken off the hubs. Hubs are on a tapered axle with a key way. . If that hub has been taken off within the past few years, it may not be so hard to get them off now.What do is back the nut off 2-3 turns Then find an area where you can do some figure 8s Not fast! they will break free! That's if the car is moving under it's own power! From the pic. looks like your is apart!
And the only place you can get replacement parts is Dr. Differential? ............................MODoctor Differential has axel shafts and brake assemblies to replace those tapered axel 64 parts using you existing axle housing. The cost was around 600 dollars but that was a few years ago. Not bad cost when you compare rebuilding all the old stuff you currently have now.
I did this on one of my 62's. I won't say it was simple but without a lot of specialized tools I was able to do it myself. It worked out GREAT!!Thanks guys. Ill update tomorrow
