RoadRunner1970
I have a 1970 440-6 4 speed Road Runner with air grabber and manual brakes, my question is at the rear of the intake manifold they have two nipples with hoses attached. One is going to the vacuum canister for the air grabber and the other hose is coming from the drivers side valve cover. I was told the hose from the drivers side valve cover should be going to the center carb and that I should only have the air grabber hose connected to the intake manifold. Can anyone verify what is correct for a factory 440-6 setup on this car? Thanks.....
