mr.belvedere
- 7:08 AM
- Jul 20, 2008
- eagle mills, new york
just replaced my single post neutral safety switch with a 3-prong switch and wiring from napa. i did this so my back up lights could work with my b&m floor shifter, as my factory reverse light switch is operated by the steering column linkage. it bolted right in, i rerouted the wires for the rear lamps, the car started in park and neutral, but now i cant move the shifter passed the neutral position. i've checked the linkage, and re-installed the switch with the shifter in park and neutral. am i missing something? i don't want to have to drop the pan and valve body in my dirt driveway on my back. any suggestions?
ps- i also did check the length of the new switch versus the old from the mounting seat to the steel grounding pin and it is identical.
