False alarm - the caps are stamped on both side and I was only looking at the one side where the #4 cap strike was very light and looked like a 1 so I had 2, 3, 1 thinking only the 3 middle caps were stamped. But the other side is clearly struck as a 4 and shows all caps 1-5 in proper order. I just looked at it too briefly before I broke for lunch. So never mind - operator error.
View attachment 1305655View attachment 1305656View attachment 1305657View attachment 1305658
I guess I need to do something about this rear main seal because the pan was on tight and I don’t think leaking. I think some through drilled holes for things like the motor mounts may be seeping. I have a few drips from higher up but surprisingly the valve covers do not seem be seeping oil. I can run a paper towel all around the gasket edge on both sides and pick up zero sign of oil. I’m afraid what they may be stuck on with. But I’m getting something around the rear and of the transmission input vs the rear main, common sense tells me it’s probably the main. I would have expected to find more oil and wetness inside the bellhousing though.
