Geri
Deceased, But not forgotton
in the early 70's a friend had a '64 dodge lightweight SS426 hemi car he bought used. the former owner was never satisfied with the performance and sold the car. my friend ran the car and like the original owner found the performance not what he thought it should be.. he sold the engine to another who put it in a dragster- beings they used fuel injection they shelved the cross ram where it sat till I got it in 1998 to put on my '62 Dart station wagon . it had the original near new Holleys still with the manifold- life is good. I put it on the wagon, and ugh- it was a slug, I started looking everything over and found the secondaries were opening only about 1/3 open, that can't be good -but why? carbs in hand- full opening was good with back barrels opening fully.
a bit puzzled I started looking at the manifold and AHA- found it.there is a machined radius on the manifold /carb spacer that allowed the linkage arm to rotate in that radius cavity. with the carbs in place the machined radius was not deep enough and stopped the carb barrels from opening, about 10 minutes worth of die grind machining in that well and the carbs opened fully for the first time since 1964. a difference of over 1800 hp ,that may be an exaggeration- but for a street car it hauled the mail. it may have been as easy as needing more carb base gaskets to cure.
