72 charger
Hey all in my 72 charger I recently had my hide away headlight motor rebuilt. Was testing it out on the car and every time i would turn on the headlight switch to test the motor the hide away headlight relay(what i came to conclude the noise was coming from) would start to buzz and make the ammeter fluctuate on the discharge side and the lights flicker. I took the relay out and tested it for continuity through the whole relay all checks out good. Took it apart seems to be ok shape to me. Wonder if coil is bad? Or any other suggestions that could cause this issue? Going to attempt to clean contacts on it and try again. Heres some pics the smaller un-opened portion of the relay is a circuit breaker. Which feeds the coil the two gold prongs are for the motor leads and the screw on the relay itself comes from the headlight switch according to my chassis manual.
