cwhubb
I need a little help from the nose bleed racers out there, I live @ 6300ft elevation and the nearest track is @ 5000ft give or take, I have a holley 950 hp, what size jets are you guys running? also should I adjust the air bleeds and pump shot or just stick with the jetting? My set up is a .30 10:5:1 440, heads flow in the 280cfm range, rpm performer dual plane,
1 3/4 headers into a full length 3 inch exhaust, Dana 60 410 gears, 25.7 diameter tires, 3500 stall manual shift b&m 727 4000lb car
