thanks, the previous owner swapped. not sure why.
I do know the low beams work each side, but not high beams.
low beams shut off but no power to high beams sockets when I hit the dimmer switch.
also my ammeter dumps to neg and bounces back over and over when I switch to high beams.
I have lots of wiring to sort out.
have not even started on rear of car yet.
I have working dome and gauge lights, (except no high/low beam indicator)
working low beams, working front turn signals
(but not hazzards)
lots of stuff to sort out as right now don't think brake warning, belt warning, oil pressure switches hooked up, side marker lights have been shaved but nothing done with the harness parts in front, but cut in rear,
no wiper washer pump/resovoir, no wiper motor,
etc. etc.
other than that,
I am in good shape. Just need a headliner, correct interior, new engine, probably tranny and rear end, some sunroof parts, etc. etc.
Ok, I take that back.
I am not in good shape.
But I own a RR and it is not getting crushed or parted out,
so at least the car has that going for it.
