Holley 600 cfm
moparjohnny
10:56 PM
ga
Can this carb be used with a metal fuel line to fuel pump set up,it has a inlet with a fitting,who sales the 3/8 metal lines and do i need other fittings to complete,i have a new fuel pump that has a outlet port for metal and inlet has the prong for the hose.i want to keep eng with factory look. thanks
I usually just pick up what I need, and build/route/bend the fuel line to meet the application. There are reducers available to go from 3/8 to 5/16 line. I also use the flexible fuel line with clamps to connect the steel lines together.
You can use pretty much whatever set up you want, to get the fuel from the pump to the carb.
